Stuck in a scene where glasses are in-front of each other.
Back glass is bending a lot. I tried to reduce the IOR to 1.1 to 1.6 but all same.
Any way to get glass effect without bending back glass…?
Thanks.
I’m pretty sure that problem is more in the model rather than in material. Most likely your glass model has some smoothing issues. Reflection and especially refraction, are very sensitive to geometry issues. Try to add extra horizontal edge loops to the walls of the glass and see if that helps to solve the problem.
Could you export OBJ file?
added.
glass.obj.zip (510 KB)
Why? Is the client asking to remove this or personal preference? This result is physically accurate.
client needs and for now I did two renders and fixed
