Glazing difference rendering locally VS backburner
The glazing just not rendering correctly on BB, all our machines are 64-bit except the BB server which shouldn’t matter. I have no clue… any ideas? thx in advance.
Can you show the material setting of it.
How about the DOT/Comma problem ?
nikki Candelero
Locally using Multi-Incremental works
Another thing i found out just over the weekend is that - if rendering locally using Multi-Incremental instead of From Map, the glazing will rendering correctly (so far)… quite strange. but for the frame amounts i needed to be render, BB & From Map would help a lot…
You might try excluding the glass from GI
k
RErender, thanks for the reply. I’m assuming you meant unchecking Visible to GI under Vray Properties. I will try that tomorrow. Another strange thing happen tonight when i was rendering the scene locally - i realized the glazing rendered out fine using multi-frame so i try to set that up on the rendernode, however I forgot to uncheck “Save map” on some of the nodes… guess what, i got the same bad glazing just like above images. I then unchecked it, hit render… it rendered out fine. Am i missing out something important? pls let me know if you have any idea. thanks.
are you rendering from a Vray camera? you might want to try turning up the hdri multiplier in the reflection override slot (a lot).
screen video
mcphep:
no it’s not a vray cam. it might be too late to change the hdri multiplier in the reflection with our schedule and how many frames we had rendered. but i will try that next time. thanks.
below is a strange problem that i had, vray rendered differently with just a check-uncheck action. All I did is: Open the file, hit render, the glazing rendered incorrectly - I could tell when it’s being calculate, so I stopped it, check auto-save, then uncheck auto-save, hit render, and it rendered out just fine… it is very strange to me. see video below if interested.
700k screen video - If you have TechSmith AVI codec:
900k screen video - EXE that packed with TechSmith AVI codec:
