Glitch!!! Corona Layered Material doesn't update animated Substance masks
Here’s details:
Below is attached a screenshot of the Material setup - that works perfectly for CoronaMtl, but doesn’t work in Corona Layered Material.
Basically key things which make it not workable:
Animated Substance → Animated CoronaMix → CoronaLayeredMaterial (as Mask)
It works perfectly if every frame is rendered separately (so manually changing frame and render) - please see Manually.jpg
But as soon rendered as Animation it give following (please see Automatic.jpg):
  • Updates just Substance, but not Corona Mix (Holding frame that was selected on timeline)
  • Not updating both (Holding frame that was selected on timeline)
Max file attached.
But!!! Same setup works perfectly with CoronaMtl!!! And works with Standard Blend!!!
CoronaMapUpdateGlitch.max (972 KB)
um how can I haz the substance material? I’m only using the substance or substance2. But yours is more better?
This should be fixed in daily builds, can you verify that it works with latest daily?
