global volume - alpha issue
When I am using volumetric material (atmospheric fog) as a global volume all object have issues with opacity/alpha.
It’s only as a global volume.
Check out “Transparent materials seen through global volume material (volumetric fog) may look incorrect.” here: https://coronarenderer.freshdesk.com/support/solutions/articles/5000516180
There is even a solution to this in there.
That page doesn’t seem to be working anymore. Is there another link that displays the solution to the problem?
Hey Psifinity, I think the article should be accessible from here - https://support.chaos.com/hc/en-us/articles/4528311915025-Known-bugs-and-limitations . Just scroll down for a bit and the issue is described with the same exact words as Maru used :smiley:
