glossy reflection settings....help
I have done a search and cant find any helpful info on creating glossy reflections on materials. v 1.09 viz4
What I have done:
tried several different reflection settings, ie - 50,50,50 - 10,10,10 etc
changed from 1 to .6 all the way down to .1
I also added some falloff in the reflection slot.
BUT I DONT SEE ANY REAL CHANGES… just seems to get a bit duller. nothing like the great examples out there on the image uploads sections.
any advice?
Arkitec
This mite help you out a little…
http://www.richardrosenman.com/vray\_absorption.htm
-dave
anyone anyone???
im on a deadline by the end of today - i could reallly use some help…
Arkitec
Actually i don´t really understand wich values you are refering to.
But to get a glossy reflection just assign a vray material.
Set the reflection to white (or something) and set your glossiness
value to something below 1. That´s it.
If you want a specific material effect maybe a picture would be helpful.
Just turning on glossiness doesn´t mean it will look like
a carmetal shader immediately .. for example
cheers
Sorry my bad, I thought you were asking about refraction…
-dave
Here is an example.
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=10063
Second image… see the glossy reflections on the table…I would like to simulate this on my tables and floors..
Here is my image
Thank you,
Arkitec
I shared my settings in this thread today:
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=10146
This scene has way too much illumination on all objects. Too much will kill reflections ultimately. There are reflections on the wood and floor but is being attenuated by by the lighting.
Ismael
