I have an image that has stainless steel on many surfaces. Infact a whole wall is SS tile. I have found if I set the subdivions really high on the material up to 70 I have a pretty clear image. But the cost is a 50 hour rendering. I have played with irr map settings and it seems that the only control I have over the noise is subdivions. Is there anything else that will clean this up? I am using lc for secondary and I do have the use glossy on.
funny we’ve been talking about similar problem on another forum. Try setting the glossy subdivisions to 8, and adjusting the qmc sampler instead. Try higher sampling such as 1/64 - 8/64 with contrast of 0.01-0.001.
Thanks Dmitry - I am rendering a region that is how I am testing my settings at full res 3000 pixels wide. Unfortunatly when I increase the QMC settings the sample rendering time went from 15 min to over 1 hour. I am asuming you meant the image sampler. Right?
I would suggest you to evaluate what sampler is doing what:
Try rendering the glossy effects to their default value, with Fixed AA.
Then slowly raise the materials subdivs until you think the AA is going to do a lot LESS work (ie. the glossy looks “allright” even without AA; say up to 32 subdivs for a 0.6 glossy).
Then the QMC AA will just be there to help clean, not to actually calculate the glossies, as in the Universal (or semi-universal) Method.
Reducing noise threshold/adaptive amount helps, but first make sure your issue is about reaching the Max subdivs in either the material or the AA (rendertimes will tell you), before actually lowering those, as they influence a lot of other QMC calculations (GI for instance).
I can say that PPT (biased mode, non adaptive) helped me when i had an elevator cabin to render, which had glossy interreflections.
Compared to the standard approach, it was WAY faster, and a lot less sensitive to glossies, as such.
I’m suggesting this given the amount of time your image is rendering for…
But maybe it’s just a 15 meters poster, so i may be wrong
