Simple Question: Does the texture-slot in Reflection/Glossyness overwrite the value-slider completely? I think so, but wouldn’t it be great to use Textures and dial the overall glossyness (or some kind of mix-amount) with the slider?
Heh, it sure does override the glossiness yeah. You’ll want to use the Corona shader called “Color Mix” and put the glossiness map in there. That way you’ll be able to tweak it the way you want to.
