Glow at ceiling joins?
I am working in Revit 2019 and Enscape version 2.3
I have consistently been experiencing glows when looking at the underside of the intersection between a horizontal and vertical plane. This behavior is not limited to roof/wall ceiling/wall joins, tho happens there. It has also been happening with-in families, and with generic models.
Has anyone else experiences this? Know any work-around?
Hey @bclements , what you’re seeing is called light leaking which happens due to thin walls/ceilings/floors etc. Making them thicker should help already. Could you please try that? :slight_smile:
Thanks a lot in advance. Please let me know in case this doesn’t resolve the light leaks.
I have the same issue consistently, my roof is 12" deep, the walls are attached to it and there is a 12" overhang outside of the space and I’m still having light leak issues.
