Glowing material ?
If you mean light-emitting materials, then it’s already implemented since ages.
If you mean post glare effects, then I think it’s useful only if you want to record youtube videos about it.
Hi maru
I tried with a teapot and I applied emitter material, but the glow effect can not see it
example, there is a MentalRay shaders Self Illumination (Glow)
mentalray
maru,
the BRDF what is it?
There is a script BRDF crown but I have not yet applied
How to use it?
script
ecXimer-CoronaBRDF.ms (331 Bytes)
here you go, a glowing teapot
yes maru,
but it is lacking glow
I find an example for me to understand better
a moment
Corona cannot do glow, because you can easily do it in postpro
Hi Ondra, thank
This option will be implemented in the future?
…but there is a different method to get the glow in 3dsmax ?
maru
examples of emitter with and without glow
rafpug, in mental that kind of glow is made by a shader that works in post, so actuall you can easily work manually in post :wink:
Hello Alessandro
Yes
I saw a tutorial from Autodesk where you put the glow effect to an object without using the post-production.
Raf
This would require participating media (like volumetric fog).
Hi maru
Hi rafpug
^______^
:wink: :wink:
maru
I am now at work, we read in the evening…
I wish you a good day ^_*
Raf
Hey guys… please do not post unless you really have something to say (that applies especially to rafpug). This is not a chat, but professional forum.
