Can anyone suggest a good 3d tree/plant generator that works with MAX/VRay, I have speed tree but VRay no like
(1.09.04d or f)
Seems like theres a few out there, is anyone using one they like?
(1.09.04d or f)
I read that www.scriptspot.com has a good tree script, just search for tree, I downloaded it but haven’t tried it out yet.
I have tree storm which has some nice trees but the plugin is a bit buggy so I convert all my trees to editable meshes… worth a look.
Craig
Pretty much same with Bionatics.. Its a bit on the slow side until you convert to Vraymtl’s and Editable meshes..
Demo it first if you can, They’re usually pretty agreeable over there.
Haven’t had a chance to test any of the other geometry based tree solutions.
Speed tree looks nicest imho when used well, but its got opacity based leaves.. which is currently quite hellish when using in vray because of the refractions..
Theres a few other Threads on tree’s.. Suggest searching the archives if possible..
will have a look, thanks
Re: Good 3d tree package for MAX/VRay?
Dman, Vlado already fixed that prob with Speedtree ( I requested
1.09.04g which had the fix) I believe it will be included in the next
update…
The G build is out. It is supposed to have improved Speed Tree support.
Wow Roy, we posted that at the same time ![]()
Yup
I also didn’t notice it was already out today. ..
Thanks for the heads up. IM’d Vlado about it a week or so ago and said he was working on it. Sweet! ![]()
Vlado you rule!
Craig >> about treestorm
Craig >> about treestorm, have you had luck with your treestorm nd its maps and photon mapping ??
im going crazy here, too much bleeding from the treestorm colors
mauarduz
