Hungry to see some sloppy bum worship? Tune in where oily backdoor fun turns into hardcore smacking sessions as these phat racks get devoured detail by detail. And if watching round bouncing bundles engulfing sturdy rods breeds your best thrills, brace yourself—these fierce ladies are relentless!
The variety’ll keep you glued full-time. From bubbly teen booties getting explored first time cheek-to-cheek style to experienced MILFs flaunting seasoned rumps that demand loud admiration; there’s enough spank bank material spanning generations!
Happy to help but I don’t quite understand your message, sorry. You talk about C4D settings: this is a 3ds Max only forum section.
Can you please explain a bit further what you want to achieve? Or post your question in the C4D section if this is related to C4D.
I don’t fully understand the question. Why would you have to save frames one by one, for example? You can save LightMix output by a) Ensuring you have the Corona Multipass Settings to have the LightMix and LightSelect passes enabled and b) Ensuring Save is checked under Multi-Pass image in the Render Settings / Save section (I’d suggest not using PSD as the output though, and just have everything saved to separate PNGs). Then you will get the Beauty pass (no LightMix), the LightMix pass, and all the LightSelects, for each frame (you can delete the ones you don’t need after rendering is complete).
