Hi everyone,
I tried to look into the settings, but didn’t find a solution yet.
Basically, I switched from cpu to gpu, where in cpu the buscket size was set to 1000.
on gpu, not knowing if the adaptive is working or not, I wanted to use the default value of the bucket to render because it manteined the 1000 size.
I couldn’t find the place where to change this setting while in gpu mode, and so I had to switch to cpu, change the value, go back to gpu.
Is there a way to change it directly from gpu setting panles?
Lorenzo
