[GPU] Distributed connection timeout
I can’t connect to a render node via GPU Production render… It says connection timeout, port 20206… But if i try normal Vray DR works fine, port 20204 though… both ports are open… Any suggestions? Tried same port for GPU but it gives random errors.
bump… Any tips/solution to fix this? I cannot use my 2nd GPU node right now.
Do you have the V-Ray RT render server running on the other machine? If yes, is there anything written in its console window?
Yes, i managed to make it connect to the node, but it isn’t rendering anything. I unchecked “use local host” and it gets stuck at 0, rendering nothing. CPU usage at 0, GPU usage at 0 on GPU node.
Tried using the local host too, but it only uses my machine GPUs.
Why does it say that there’s 0 lights, 0 primitives, etc…? Local machine has 3x 980 Ti 6GB, GPU node for now has 1x 780 Ti 3GB for testing…
Here’s a screen of the console. Vray 3.40.01
Please send me the scene for investigation at peter.matanov@chaosgroup.com
Are you able to render a very simple scene with a few basic primitives and a light?
Have you got the same result when rendering with RT CPU instead?
Would you please double check that you are using the same V-Ray version on all machines participating in DR, make sure also that the correct V-Ray RT Spawner is started in case you have multiple V-Ray installations.
Got it working today, apparently it was because both machines had different nvidia drivers… It was giving a “Memory allocation failure” every time i tried to render on the node, drivers updated, it’s working now!
