Gpu dr
When I pick DR when using GPU, nothing happens. If I uncheck DR, it renders fine. Is there something I have to do? I have one render node and I ran the setup on that machine.
Hi, thanks for posting. Please read this docs page and complete the steps there - https://docs.chaos.com/display/VMAX/…uted+Rendering
Does it have to be CUDA? CUDA has always run slower for me. I use RTX, which is faster by far.
It should work with CUDA and RTX. Were you able to complete your distributed rendering setup for GPU and does it work?
No, it doesn’t work. When I pick DR for GPU, nothing renders.
Have you completed the steps in the articles from my previous post? Try a new simple scene. For instance create a few default objects like boxes or teapots and a simple dome light with no texture. Raise the resolution and the sampler settings a lot in order to give a bit of time for the slave computer to join rendering before the frame is rendered. If this does not work, please contact the technical support for a team viewer session - https://support.chaos.com/hc/en-us/requests/new
In case a scene like the simple one described above renders successfully with distributed rendering, please send us your production scene that does not render for a test over the support contact form (linked above).
