GPU ENGINE- uvw randomizer with stochastic tiling and rotation changes still not applying to DISPLACEMENT
Has this been acknowledged yet? I made a forum post over a year ago and was told the problem couldn’t be replicated. I’ve managed to replicated it every single time I have tried across at least 10 scenes across 2 machines.
Am i the only one with this issue? I see that there is posts from years ago in other softwares stating the same problem met with the same answers but i’ve never gotten it to work once so i just don’t believe it cant be replicated.
to be more specific, using the rotation variance inside of the randomizer leads to no difference in the output of the displacement. id like to be able to change the rotation steps to line up a pattern properly.
Hello @sean_krouse Could you please share with me some visual reference so I can observe the issue you are facing myself?
If you are able to reproduce it in a new, simple scene, please, share it with me to test.
Regarding the old posts, please, link those as well, as well as the others related to other software so I can investigate fully.
