Vray 6 hotfix 3, if im running an interactive render in GPU mode, and select an object that has the default edit polygon modifer in the stack, if i select it, it triggers the render to restart. If im in create mode as opposed to modify, its fine, also if i add an edit poly modifier on the stack its fine. See attached video.
editpoly and ipr.zip (815 KB)
I forgot to mention, its doesnt do it in cpu mode of course.
Thanks for the report. In the mentioned scenario, the IPR refresh is triggered by a 3ds Max prompt (which happens only when the Edit panel is selected). In CPU, things are wired differently, hence why the refresh does not occur there. We may fix this eventually.
