Hi all
I’m rendering on the GPU and setting the following to 0:
Max Subdivs
Noise Threshold
Max render time
The render finishes, showing the following last lines in the console:
[2017/Sep/10|18:30:19] V-Ray: Noise threshold lowered to 0.000031 with 7.7 percent active pixels.
[2017/Sep/10|18:30:19] V-Ray: Noise threshold lowered to 0.000015 with 7.7 percent active pixels.
[2017/Sep/10|18:30:20] V-Ray: Noise threshold lowered to 0.000008 with 7.7 percent active pixels.
[2017/Sep/10|18:30:20] V-Ray: Noise threshold lowered to 0.000004 with 7.7 percent active pixels.
[2017/Sep/10|18:30:20] V-Ray: Noise threshold lowered to 0.000002 with 7.7 percent active pixels.
[2017/Sep/10|18:30:20] V-Ray: Final noise threshold set: 0.000000
The image is 8K, with small recessed holes and the holes are still a bit noisey.
However, if I carry out a small limited region of a few of the holes, the render is smooth.
Cheers
Also, if I set the Max Subdivs and Threshold to 0, can I control the render by time only?
