GPU render doesn't work for second scene
I’m working on two interior scenes and I need to apply the changes from one scene at the other scene. So, both are open. I can render scene A, but if I try to render scene B, the GPU rendering doesn’t work for scene B anymore, I get a lot of error messages. If I restart scene B than I can render this scene. Each scene needs approx. 2GB VRAM only.
-Micha
 [FONT="Roboto Bold"]Preparing renderer...[/FONT]
Creating bitmap manager
Bitmap manager created.
Scanning scene for light plugins.
4 lights found.
Using adaptive light evaluation with 8 lights.
Light tree is enabled with clamp coefficient 0.1 and even split coefficient 0.5.
CUDA renderer requested.
CUDA renderer plugin already loaded.
CUDA renderer plugin instance successfully created.
EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance.
Using low thread priority.
Max ray intensity is enabled: rendered result may have incorrect brightness.
Using Embree ray tracing.
SDTree statistics:
Total number of faces stored: 5992164
Max tree depth: 49
Average tree depth: 26.8802
Number of tree nodes: 2042901
Number of tree faces: 17982271
Number of tree leaves: 898449
Average faces/leaf: 20.0148
Memory usage: 712.73 MB
Building static SD trees took 1334 milliseconds
Using 0.92 MB for adaptive lights buffer
Running RTEngine
Initializing CUDA renderer with on-demand texture loading...
Failed to allocate 2000 bytes, device 0, buffer
Failed to allocate 6599544 bytes, device 0, buffer
Failed to allocate 212992 bytes, device 0, buffer
Failed to allocate 512 bytes, device 0, buffer
Failed to allocate 16 bytes, device 0, buffer
Failed to allocate 262144 bytes, device 1, buffer
Failed to allocate 2000 bytes, device 1, buffer
Failed to allocate 6599544 bytes, device 1, buffer
Failed to allocate 212992 bytes, device 1, buffer
Failed to allocate 512 bytes, device 1, buffer
Failed to allocate 16 bytes, device 1, buffer
Failed to allocate 262144 bytes, device 2, buffer
Failed to allocate 2000 bytes, device 2, buffer
SDTree statistics:
Max tree depth: 49
Running RTEngine
Failed to allocate 32 bytes, device 2, buffer
Enabled Light Tree on GPU
Failed to allocate 4 bytes, device 0, buffer
Failed to allocate 4 bytes, device 1, buffer
Failed to allocate 4 bytes, device 2, buffer
Failed to allocate 11724 bytes, device 0, buffer
Failed to allocate 11724 bytes, device 1, buffer
Failed to allocate 11724 bytes, device 2, buffer
Failed to allocate 88 bytes, device 0, buffer
Failed to allocate 88 bytes, device 1, buffer
Failed to allocate 88 bytes, device 2, buffer
Error transferring render mask to device 0
Error transferring render mask to device 1
Error transferring render mask to device 2
Failed to allocate 32 bytes, device 0, buffer
Failed to allocate 32 bytes, device 1, buffer
Building light cache.
Tracing 1000000 image samples for light cache in 64 passes.
Using 153.18 MB for light cache preview buffer
Bitmap file "D:\Texturen\Licht\Spot_02h.png" loaded.
Merging light cache passes.
Light cache contains 7948 samples.
Light cache base memory usage is 1.2 MB.
Using premultiplied light cache.
Using adaptive lights ver2
Failed to allocate 240000 bytes, device 0, buffer
Failed to allocate 96 bytes, device 0, buffer
Failed to allocate 240000 bytes, device 1, buffer
Failed to allocate 96 bytes, device 1, buffer
Failed to allocate 240000 bytes, device 2, buffer
Failed to allocate 96 bytes, device 2, buffer
Failed to allocate 414336 bytes, device 0, buffer
Failed to allocate 414336 bytes, device 1, buffer
Failed to allocate 414336 bytes, device 2, buffer
Failed to allocate 1252251 bytes, device 0, buffer
Failed to allocate 1252251 bytes, device 1, buffer
Failed to allocate 1252251 bytes, device 2, buffer
Failed to allocate 384 bytes, device 0, buffer
Failed to allocate 384 bytes, device 1, buffer
Failed to allocate 384 bytes, device 2, buffer
Failed to allocate 52 bytes, device 0, buffer
Failed to allocate 52 bytes, device 1, buffer
Failed to allocate 52 bytes, device 2, buffer
Adaptive light grid built in 4.07 ms.
LightCache contains valid adaptive lights data. Building GPU adaptive lights...
Failed to allocate 181664 bytes, device 0, buffer
Failed to allocate 181664 bytes, device 1, buffer
Failed to allocate 181664 bytes, device 2, buffer
Lightmap successfully loaded.
GPU light cache: 11354 samples stored.
GPU adaptive lights v1 built successfully
[] D:\cgrepo\vraysdk\samples\vray_plugins\rt_private\rt_opencl_pri(3579) : CUDA error 2 : unable to allocate enough memory to perform the requested operation (out-of-mem)
Mtls 13.12MB, Geo 832.53MB, Lights 0.00MB, LightCache 0.80MB, Reserved 23.12MB (data index 302775)
Total GPU samples 0
Device 0 statistics: N/A
Device 1 statistics: N/A
Device 2 statistics: N/A
Number of raycasts: 13863542 (2.77 per pixel)
Camera rays: 1000203 (0.20 per pixel)
Shadow rays: 7719293 (1.54 per pixel)
GI rays: 6927264 (1.39 per pixel)
Reflection rays: 846407 (0.17 per pixel)
Refraction rays: 7838 (0.00 per pixel)
Unshaded rays: 2166110 (0.43 per pixel)
Number of light evaluations: 12903920 (2.58 per pixel)
Maximum memory usage for resman: 0.00 MB
Number of intersectable primitives: 5992177
SD triangles: 5992164
MB triangles: 0
Static primitives: 13
Moving primitives: 0
Infinite primitives: 0
Static hair segments: 0
Moving hair segments: 0
Cleaning up bitmap manager
Maximum memory usage for texman: 0.00 MB
Could you please share the project with us so we can investigate in detail? If this is alright, please send us an archived copy (V-Ray > Pack Project) via email or a file-sharing service of your choice
Some days later now I tried to repeat the situation but it works. Also rendering both scenes at the same time is no problem. I will keep my eyes open.
