Currently, in Maya it’s not possible to select V-Ray GPU as the engine on macOS. The option is selectable on Cinema4D build, but not on Maya for some reason.
I don’t use this option to render via GPU on the Mac, but it allows me to pick GPU rendering for the distributed rendering which I run exclusively on the remote server both for IPR and Production render.
I know the option can be added back via VRAY_MAC_GPU but I was wondering if you can add this option back to Maya on macOS without having to set that variable?
Thank you
