V-ray 4.2 for Sketchup GPU rendering does not handle transparency well. When I pace a png.texture with a logo on a surface then when rendering with CUDA the transparency surounding the image / logo gets black in the render. When I render just with CPU all goes well. Image 3 is a screenshot of Sketchup where you see in the outliner that there are 2 components. The logo-component has exactly the same shape and roundings as the gas-tank and is placed 0,5 mm away from the gas-tank surface. On the 2 render-images you see clearly the difference.
You could say, why making a fuss, but rendering with CUDA, specially when you have a powerful GPU, goes way faster. For 1 image CPU is ok, but I need to render an animation of 1200 images. Time is money.
Try to reverse the faces(select the faces > right-click > reverse) of the text’s plane.
If this doesn’t work, please share the file so I can investigate it on my side.
If this is alright, please use the Pack Project tool(Extensions > V-Ray > Pack Project) to make an archived copy of the project and send it to us via the link below.
https://support.chaos.com/hc/en-us/requests/new
Thank you for reporting this!
The issue is reported under SK-3826
It is happening because of the stochastic layer in the car paint. One workaround is to use car paint from the library without a stochastic layer.
