GPU Rendering V-Ray Messages - "matched no devices" (it's because those devices have been removed from PC and upgraded)
How can I get rid of these messages in the V-Ray Messages dialog box ?
It is telling me that the Query for the 3 x “geforce gtx 1080 ti gpus… matched no devices” - that’s because those have been removed from my system and replaced with an RTX 3090.
When I installed the Geforce drivers for my new GPU I did a clean install of those new drivers…
Please see attached screen capture.
Many thanks.
I would recommend executing the following steps which should remove those messages from the render log:
* open an empty 3ds Max scene and switch to V-Ray GPU
* go to render setup, “V-Ray GPU Render Devices Select” rollout and disable some random device from there, then start rendering, then enable the device again
* go to “Select devices for V-Ray GPU rendering” (device selector) from start menu - the list should be refreshed with the newly installed devices
Philip
Thanks Phillip, that fixed it :slight_smile:
