GPU usage when rendering with CPU ?
noticed something strange (?). I launched a rendering using DR CPU, as usual, and i noticed that the GPU (rtx3090) was at 15-20%, even if i did nothing special, just watching the Task Manager.
When the CPU rendering was finished, the GPU came back at 1-2%
Is this normal ? What’s going on when with the GPU when rendering on CPU ?
Thanks!
Could be some hardware accelerated VFB effects?
Lens Effects aren’t enabled in the rendering
tested on another workstation, same result with 15-20% of GPU usage when rendering (1080ti)
@muoto do you have Denoiser enabled? If Post Effects Rate is set to update frequently, then 15-20% of GPU usage during rendering should be normal. Are you testing with the same scene?
Nope, no denoiser, same scene, same two workstation just 2 different video cards (1080ti and 3090), same max, same vray
Could you share a piece of the scene which shows the behaviour with Support, then?
OK, i have just done it!
Thank you! :smile:
