Hi
Almost in all the scenes i want to use GPU (RTX 3080 Ti) for real time testing it mostly freezes and loads and doesn’t work, i have to restart both sketchup and vray. When I switch to CPU it’s mostly normal, but I’ve invested a lot in the GPU I want the realtime process to do better.
Test tree is the lightest scene I did for testing. for interior scenes it’s 100% ice and doesn’t work in real time
Link test tree: https://drive.google.com/file/d/16Yz3Fpp9K4MzmrBNrl0SRO\_zVZqAYnYg/view?usp=Shanghai
thank you chaos all so much!
I have a similar problem rendering with my CPU where the interactive rendering just doesn’t start and will only restart after I change a scene or restart SU.
my computer (i9-10850k, 64G ram, RTX 3080 Ti) tried many times it freezes in scenes and I have to exit sketchup he vray and have to go back in. when i reinstall vray 4.2 it seems to be better
Hello @og_tran
I tested the project on my side and was not able to reproduce the issue. Would it be possible to record a video so I can follow the exact steps taken so I can reproduce it and investigate on my side?
@gus_robatto can you please share an example so I can test it on my side? If this is Ok with you please use the Pack Project tool to make an archive and upload it in the link below.
Please include the V-Ray version and SketchUp version.
