I have a question regarding creating a gradient style frosted glass. I have attached an image of Bisazza tile and I wanted to create a frosted glass pattern similar to the tile pattern that Bisazza offers. The glass would be frosted on the bottom and become clearer as the pattern elevates. The frosted opacity would be scattered and shifting as the pattern goes up. Any ideas would be appreciated. Thanks.
you should be able to get pretty close by mixing (or better use scicAniComp) a gradient ramp and a tile map
Probably the easiest way is to do it in photoshop. First make gradient, then add some variation with Clouds filter for example (another layer with 50% opacity on top of your gradient) and then use Patchwork filter. You’ll get this:
Hit the above with some noise >>> stained glass filter >>> white gradient >>> mosaic tile filter.
Those examples look great. Thanks for all of your help everyone. This is really going to help me out.
JeffG2: My tile looks nothing like yours. Can you post your settings for me? I would appreciate it, thanks.
