Grafikkarten
Hello!
As I’ve read, Vantage supports two graphics cards. I have an RTX 3080 Asus and a GTX 1080 TI from Asus will both be used in Vantage? Can you activate the graphics card somewhere in the settings?
Yes, up to two compatible cards can be used. The application automatically detects them. If there are more than two, it selects the two that seem best. We have not yet implemented UI for selecting the cards to use.
However in your case the second card is much slower than the first one. It does not have raytracing acceleration, etc. Also keep in mind that the memory of the two GPUs is not added together - each uses its own memory. So there will be little benefit from using the second card. In fact, things could even run slower than only on the 3080. The PCI-e link between the cards is a bottleneck.
If you need to run Vantage on only one of the cards, you can do it from a command prompt like this: vantage.exe -d 0 *or* vantage.exe -d 1, where the number is the index of the GPU and you can see the list of detected GPUs with their index from Help->Debug Log.
Thank you !
Please check this forum post for a comparison between 3080 and 1080 Ti performance with Vantage:
- 3080 is anywhere between 6.2 and 13.5 times faster than 1080Ti
Greetings,
Vladimir Nedev
What happens if I use two Asus RTX 3080 cards of the same type, do I have twice the speed?
Two identical cards will be able to split the work well between each other. So you may get close to twice the speed, but it depends. Since the results have to be transferred from the second GPU to the display GPU on every frame, the PCI-e limits the maximum possible FPS (it gets lower for higher resolutions). So a second GPU will only be helpful if the scene renders at relatively low FPS. If the cards are connected with NVLink the maximum framerate is higher.
Note also that Light Cache is not available for dual GPUs - this slightly reduces speed in interiors too.
Thank you!
Make sure to use the denoiser when rendering a final image or sequence.
The nVidia AI one in Vantage 1.3.0 can save you way more time than even a second GPU.
Also, if you are rendering an animation, you can start a second copy of Vantage on a different GPU and render a different animation range on each copy of Vantage.
This will eliminate the overhead of moving the rendered frame between GPUs. You will also be able to use the light cache, which can be very important for some interiors.
Greetings,
Vladimir Nedev
How can I start a second copy of Vantage in a different GPU? Command Prompt vantage.exe -d 0 or 1 does not work get a message command could not be executed.
Are you in Vantage’s directory ?
You can just copy the Vantage Desktop shortcut and modify its properties to include the “-d 0” and/or “-d 1” options.
Greetings,
Vladimir Nedev
Eine Verknüpfung von vantage.exe anlegen und dann auf (vantage.exe -d 0) ändern oder? Und diese dann starten.
Yes, one shortcut for “-d 0” and one for “-d 1”.
It’s usually easiest to copy and modify an existing shortcut.
Greetings,
Vladimir Nedev
Does one RTX 3090 render faster than two RTX 3080s?
It depends on a lot of factors:
- are you using the 3080s in a single Vantage instance or in two separate Vantage instances to render different parts of an animation
- the FPS at which your scene is running
- is it an interior space that benefits a lot from the light cache (which is disabled when running on 2 GPUs with one Vantage instance)
Greetings,
Vladimir Nedev
One 3090 orTwo 3080 cards for the same scene it is an from interior scene rendering.
Hard to say without testing the exact scene and render settings.
In any case, 2 3080s won’t be twice as fast as 1 3080, that’s for sure.
The 3090 also has the benefit of having more than twice the RAM, so if you are choosing what to buy, that might be a good reason to get the 3090.
Edit: Oh, you already have a 3080, just reread the original post.
Greetings,
Vladimir Nedev
What happens if I use a 3080 and a 3090 do the cards work together optimal or do I have restrictions?
Yes, they should work together, however you are limited by the smaller amount of VRAM when you want to use them together. In this case 10 GBs for the 3080.
Greetings,
Vladimir Nedev
Hallo habe jetzt eine RTX 3090 und eine RTX 3080 in meinen System möchte gerne RTX 3090 für Vantage (vantage.exe -d 0) und die RTX 3080 für Cinema 4D Nutzen (Cinema.exe -d1) liege ich so richtig einfach eine Verknüpfung Anlegen und dann umbennen oder? Wo kann ich sehen ob er wirklich die RTX 3090 für Vantage anwendet und die RTX 3080 für Cinema?
I am not sure this option works in Cinema 4D ? Maybe C4D always uses the GPU connected to your display ? You have to check this in the Cinema4D docs or forum.
As for Vantage, you can see which GPUs are being used in the lower right corner of the Vantage window.
Greetings,
Vladimir Nedev
