grainy vrayspecular render element
hi,
i have a scene rendering without GI. one vraylight-hdri for reflection and one vraylight-hdri for lighting and an ambientlight.global subdivisions
blurred vraymaterial with Rglossy of 0,85 brings out a specular pass that is very grainy. if i layer this twice it look ugly, also because this grain moves.
any idea either than making the noise threshold smaller down from 0,005 to 0,0001 ( there it is … better) but rendertime is 4 times longer !
…max2018 file attached
thanks for help
thomes
grain.zip (2.34 MB)
Yeah that’s true, you can’t clean the Specular RE only without adding more sampling and increase the render time (more or less), but you can Denoise it. The V-Ray Next beta has an option for this in the UI or you can also use the plugins for Nuke.
is your light source small? it could be that you need to use local subdivs and increase light and shader subdivs
thanks boys, so we have to wait for next beta…
dmitry, i have a maxfile attached if you want to look in. small scene…
V-Ray Next Beta 2 is already released so you can try it out.
thanks svetlozar!
can you please check the “use camera path” feature. it is still not fixed after half a year. am i the only one that needs this ?
We will be removing the “use camera path” feature for the light cache. It prevents V-Ray from optimizing the rendering and ultimately leads to longer render times.
and for irradiancemap ?
It will stay for the irradiance map.
but it does not work since 8/17
Ah yes, this will be fixed for beta 3.
your word in gods ear 8)
