Graphic Film to Glazed Partition
Can anyone tell me a good material solution to create a opaque graphic design on a clear glazed partition 12mm thick !
I have tried different solutions which kinda work using a box and setting mat id’s to both sides ( one side clear glass and the other showing the grahpic image with an opacity map…but the I.O.R. seems to be wrong ?
thanks
Tony
I’d say use a vrayblend material with the coat material beeing the sticker/graphic and it’s blend-map beeing the alpha of it.
Regards,
Thorsten
i have tried this and i get the graphic on the front and back side ?
Regards
Tony
Use a Vray2sidedMtl for the coat material? One side being the graphic, the other side being white.
Or do a proper UVW Map instead of the default one :stuck_out_tongue:
Regards,
Thorsten
P.S. it DOES have two sides and thickness, does it ?
Yeah its just a matter of selecting the right faces are applying the proper UVW channel (and mapping) to each.
or… the quick and dirty way to do it is place a single poly infont of the glass by say.. 1mm map it and away you go.. i do that sometimes when a client wants something turned around double quick!
Thanks chaps !
I have used the vray blend material… which works very very well !!!
Cheers
Tony
HI
here is the setup i use ..
the file ..
http://rendertime.co.uk/vray/new.rar
Hey Natty… been awhile.
Nice render :smile:… VERY nice.
Hey thanks dude … and yes it has been a while .. lets hook up on msn soon.. :wink:
Hey Natty :smile: , Very nice indeed.
Thanks dude .. :wink:
indeed mate indeed.
schedules and time zone permitting of course :smile:
hehe … absolutly mate
