Hello all - I am loving Enscape, its truly incredible.
However, does anyone know how to make the grass not appear black from certain angles and or from far away..
Its fine up close but far away appears black. Thanks
@ACW Please check in the Enscape settings if you have activated outlines.
Could you share a screenshot of the black grass?
@ACW I think from this distance all details are reduced to a minimum and you usually see only the dark green color of your texture image in your Revit material.
So if you want a brighter color, please try to load a brighter colored image in your Revit material.
How does the grass look like from this distance if you export a Screenshot to file?
thanks for the steer. - I changed to a lighter colours grass - or actually the “plant” material and it looks much better
