Hi @Poli_1 , thanks for your report and I’m sorry to hear about this issue.
First off, does it make a difference if you move closer to the scene (moving, not adjusting the field of view) and/or if you change the projection mode to perspective for example? Also, is there a chance you could also please install Enscape 3.4.2 (even just temporarily if there is a reason you’re still using 3.3), as this issue may only persist with 3.3 on your machine?
