Grass Fur - Reduced Edge?
Any way to make the edges relax or curl down a bit when using fur for making grass ? Where the grass meets the sidewalk I would like the edge to not show the grass edge so much.
You can use maps.. Prepare a b&w image and paint the borders with b&w gradient and use right click - wray uv and choose fit.. Add the same texture as maps in needed areas.. For fur texture you can set any grass textures..
