Grass Height in update?
Hey Guys,
Is the grass height adjustment feature implemented in the Revit update also?
Hey @JDH_2 , you can use the following keywords in the material name to change the appearance and length of our grass, from shortest to tallest: short grass, grass, wild grass, tall grass.
But, we have not implemented a dedicated grass height adjustment functionality which is available in SketchUp, but it’s on our agenda and the topic just received a further upvote through your voice! :wink:
Thanks heaps for that Demian.
If the adjustment allows you to go lower than “short” I think would be good to implement but this way does work well also. Cheers.
@JDH_2 , any special use-case scenarios for even shorter grass? :slight_smile: I’ll gladly forward the further feedback to our developers.
Artificial grass, putting greens, bowling greens, manicured lawns, cricket pitches, (sports grounds in general) as well as non-grass uses like carpets, rugs, fur, …
@Gadget_1 , I’ve added your voice in form of a further upvote to the existing topic “Adjustable Grass Options” as well. :wink:
Hey,
maybe I should post this in another topic, but I was wondering if the grass material could also be applied to the side of a wall in Revit and also changeable in length on this wall?
Would be very handy to create a hedge.
Kind regards,
Sem
@Magimes this is not yet possible, but it is filed as a feature request on our agenda. :slight_smile: The topic just received a further upvote through your voice!
Grass only appears on horizontal surfaces (<70Âş)
There are ways to get it to almost work, but it doesn’t look good:
(Need a way to change the “leaf” shape and a random dispersal that also changed dependent on the Z axis rather than just X and Y)
I agree with @Gadget_1 on the use of an even shorter grass. We use artificial turf on several projects.
Kind regards.
+1 for grass on vertical surfaces
+1 for finer control of grass in Revit (as in sketchup)
@jgendell , added your vote to the topic! :slight_smile:
@Pieter_2 , +1 for each topic as well, thank you very much!
Yes pls, shorter grass or more control over grass parameters. Great work so far!
Thanks for your feedback, forwarded as well of course! :slight_smile:
Same as grass. I hope the word “carpet” will do also since they both different properties.
+1 for more control over grass. Been nearly 2 years since the original post… Would rather have control over vegetation as well as a wider variation. Moving trees is cool and all but that doesn’t matter in still renderings…
+1
üush that up a bit, grass is still a bit too “bushy” and could be mor “english-golf-course” like :wink:
Hi there @luzius !
Thanks for the suggestion right away, given that this is a bit of an older thread I wanted to also let you know that feature requests or asset requests generally can now be forwarded directly to product management via our Chaos Ideas Portal as detailed here: Chaos Enscape Ideas Portal (How to forward/upvote Feature/Asset Requests directly)
Of course if there are any other wishes on your mind feel free to share them too, and/or comment/upvote any of the existing requests if you like.
If anything is not entirely clear let me know!
