i’m trying to make grass material any advices?
diffuse map + brighter translucency map (fraction=0.15)
here’s render tests
grass-vray - 2sided from Vray, secend is corona test (on top reflection level=0, middle RL=1 IOR=1.1, bottom RL=1, IOR=1.25)
I find it handy to put the instanced diffuse texture map into a color correction node so you can increase the saturation and brightness of the translucency slightly.
Thx
will try it.
reflection IOR affects reflection, it was set by color=white level=1, glossiness and IOR. in setup change reflection IOR, not refraction ![]()
In to see the results!
So much quicker than vray for this patch of grass with forest.
vray took about 7 minutes while this looked fine after about 2 minutes.
Just wondering about the DOF, the specks in the background from their reflectivity dont seem like they should (possibly more blurry out of focus?), what setting will help these out?
Yeah thanks, i think i had my glossiness too high. Turning it down made the highlight bokeh much smoother.
I started this topic and it turned to Grass Mat too. Check it out.
