Hi All
When adding grass or carpet to an object the both appear flat.
I use the latest Enscape with Rhino 6.0.
Hi All
@borg_design , in the first instance, can you please make sure that Grass/Carpet rendering is enabled in the first place:
If that doesn’t do the trick, please also make sure you followed the steps detailed in our knowledge base Enscape-Rhino material article.
Should that still not work, can you please also send me a screenshot of your material settings used?
I found the issue. I had my Rhino view in isometric which removed the grass height effect.
