I have the standard vray grass material thing and it is reflecting a green color on my windows roof, siding etc…is there an option I am missing
I use the vray override material. Just set your gi color.
turn the saturation down in your irradiance map. I usually by default set it to about .65
Hey percy, Do you always turn down the saturation, even for scenes without large saturated areas ? It sounds like a pretty smart way to control the bleeding.
Regards,
Mike
basically ya. But its a default setting I use with a preset. Ill adjust it from there if needed.
Great…Thanx…That worked great…
