grass scale problem
hi..
in fur standerd parameters lenght is 4 when i do it 0.8 to get the real scale of grass i don’t get a real density even when i do count on max ‘see ttach’ !!!
and i dont know where i can foud the area parameters to scale it
10 isn’t the max in “count (Area)”
don’t use the slider and type the number instead
try typing 100 instead of 10
that will work
i get an error when make it more than 10
Hey @moneech ,
How big is the geometry you assign Fur to? Does the error occur in Interactive rendering?
Best,
Ana
hi ana.i found that when i do hdri scene or in Interactive rendering i dont found this error
We’ll need the V-Ray for Revit log file. As far as I know, you’re communicating with our support team, so it’s ok sending the log to them.
i don’t know how but it’s soled …thank you so much
We need to investigate what was causing it anyway.
