Grass
Hello Sir/ma’am,
Hope you are good!
Well, I am using Revit 2021 and I want to make realistic grass in it. I have one screenshot for reference. I need Type 1 grass. How can I get that in Revit?
Need guidance
-SP
Needed this.
Enscape Grass Material 01 - Revit 2021
You’ll need a good texture. Darker version of this material (it’s a good start). See attached. Make sure Revit materials have the keywords “grass”, “short grass”, “tall grass” or “wild grass”.
This article is a useful starting point. https://blog.enscape3d.com/best-practices-grass-in-architectural-design
I tried but still didn’t get the same result as shown in pic 1.
Please post an image that illustrates your result.
Sure, PFA
What is different about the grass in the reference image and your image that you’re trying to accomplish? In the reference image:
  • The material color is different (some darker and lighter areas)
  • The angle of the sun is different (lower from the lower right)
  • The elevation of the camera is lower
Start there.
try this map snip! Just make it really large! I’m sure you will be impress by the variety texture in the in the blade.
Sure
