Gray horizon bar in Clear atmosphere mode
Hi! My “problem” is when i go to the atmosphere in the settings bar and choose Clear in the horizon part there is always a gray bar that ruins my perspectives… The sky is great andthe clouds are good but that gray bar is always showing… Is it possible to remove it? I tried to use a skybox image as alternative but the image is really zoomed in as soon as i load it to enscape and becomes blurry… In the image as you can see everything is great… but that dark gray bar ruins the image…
The grey bar is the horizon. There is no sky under the horizon because that’s were the earth is visible. To hide the grey line, we offer different horizons.
is it possible to “low” the horizon so it doesen´t appear in the image? The other horizons wil not fit the scenery … Is there anything i can do so that grey bar doesen´t appear? Without changing the setting from Clear
Other than post-production, you could put a white “skateboard ramp” in the background of your model?
i don´t think it would work… im starting to put some trees and bushes… but i would like to know if i have to do that all the time or is there another alternative
I use skies like this to avoid the strong horizon breaks. Maybe the default background could get a soft ground border too.
thank you for the help… i tryed the image and it was actually nice…
