has anyone seen green dots when using VrayDisplacementMod on an object?
Any solutions?
It also puts holes in the objects alpha chanel, as well as these small bright green dots on the rgb channel.
its with max 8 + vray 1.5R3
thanks
Nick
Any solutions?
thanks
Nick
Can you post an image? Are you using 2d displacement or 3d displacement?
3D. Here you go, Vlado…
Cheers
Nick
Are you getting UVW errors from vray when you render? If you are using planar uvw’s you should try box.
Thanks for the suggestion, but no uv errors and it is box mapped
cheers
What kind of trees are those ?
nikki Candelero
onyx. vray proxy-d
