Hi, I’d like to see an update where materials named “Green wall” etc. produce 3D plant foliage (on vertical/inclined surfaces). Similar to how the grass currently works, but with leafy plants instead of grass blades
Lumion benefits more grass options. In fact it uses a set of models to choose from. It includes some ivy leaves that converts any volume to plants. This idea is achievable easily.
I think technically Enscape is capable of adding some more foliage to choose from. Using this tricky way almost every volume could be converted to trees or plants. Even there might be a mixture of several foliages.
Very cool Jorgensen. I assume you purchased this green wall Sketchup pack to create it then? https://gumroad.com/l/tOyB
I’m curious about it. The plant models looks great, but I wonder if the materials include any additional maps besides diffuse/albedo? (bump, normal, roughness etc.)
