guesslensshift for each batch render view?
Is there an way to have VRay use the guess lens shift command before each render? I modified my render button to do it when I manually render but batch doesn’t use it.
cantu.john866
I do not believe there is way to do this in V-Ray For Rhino 2.0. I will add this as a feature request for 3.0.
At this time the only solution would be to run it before you save the 3dm.
Could be great to get a camera option for automatic lens shift correction.
Do you want to have that enable all the time or should we provide a way to disable the automatic lens shift correction?
I don’t want it enable all the time,because most of the time I don’t like a perfect lens shift,I always set it a little bit lower.
Renee
An option to enable/disable an automatic would be useful.
Enable/disable - I can’t use it when doing overlays with rhino viewports so would ruin that workflow.
Ok. Thanks
Named object positions and layer states, from the -panels- drop down would be really useful as well…set up with each view.
