gw:Ivy - Grow Test (Animation)
Hi there,
This is a little test animation I made with gw:Ivy.
What a fantastic plugin !!
The Animation (PAL, DivX, 30mb)
http://sorceress.netfrag.org/optix/s\_Ivy.avi
Very nice… Is this a newer version of the ivy plugin? because i thought it was not able to animate before..
Looks very cool.
Greets,
Niels
I used version 0.76b. At least for the “age” parameter it works. I don´t know about previous versions. I came across this plugins some days ago.
yes it’s a fantastic plugins ! I’m trying it yet and i’m very impressed… what are you using to render this animation ? the irrmap animation mod or other ?
the ivy generator plugin can be found where?
mh
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=21030
my test is short but its using the new irradiance map animation setting
There is also the ivy generator program. Not sure if someone has mentioned this already.
http://graphics.uni-konstanz.de/~luft/ivy\_generator/
haha thats cool!!
thaks for the tips :wink: Da_elf when i have the time i’ll try :stuck_out_tongue:
I used Irr.map single frame/Light Cache.
@dimskapunk: This plugin is based on the Ivy Generator
by Thomas Luft
One little problem I noticed… when using backburner the Ivy object
was reset to the world coordinates center. But I haven´t investigated
this behaviour closer for the moment. I helped myself by setting the Ivy object to world center by default and build the geometry around it.
I have another animation in the queue.. but it won´t be finished before monday :).. hopefully
cheers,
when did this sneak in? it’s wunderbar! :grin:
beats me, the post date should be there. was done in the original post about the max ivy generator which was posted before this one
i meant the new irradiance map animation settings. i like em.
ooooo. sneeked in in rc5 i think
