Had to roll back to 2.5
I was getting a lot of issues with some materials looking overly dark and the GI bleed and lighting quality (set on Ultra) not looking as good as it did previously. I rolled back to 2.5 and stills looked a lot more like I expected them to.
I also would like to mention I was working on a project with many interior views of 3 separate school buildings in one file and I really think that exposure settings need to be saved on a per scene basis. Auto- exposure is unreliable to result in a well exposed image and when you have 20+ cameras of various rooms, you really want to have the image settings to be remembered as you go back and forth and revise, etc. It got to the point where I was writing it down on a notepad because each room/scenario needed different exposure settings.
:frowning:
I have noticed that the auto exposure and exposure in general has changed - I used to be able to leave it alone, now I find that I have to tweak it (especially between inside and outside views… I think that the “sky” is blasting out more light than it was previously)
I also had materials that were darker values, like purples, dark blues, and darker mahogany woods and they were rendering almost black. When I rolled back, they rendered as expected.
We’re sorry to hear that you feel that v2.6 isn’t to your liking. Unfortunately based on your description I can’t come up with an explanation why this might happen at the moment. Not aware of any changes to how auto-exposure works between 2.5 and 2.6 and neither any material brightness related differences either.
What certainly did change is the quality of indirect lighting - it’s usually much closer to reality now especially in indoor scenes with artificial lighting. This might have an effect on brightness, since indirect lighting is now a lot more precise, e.g. where previously light was able to leak through walls this isn’t happening anymore.
We’ll gladly have a look at some before/after screenshots or even the project file if you’re able to share that with us!
Were the issues mainly on interior shots, or both interior and exterior?
All Interior shots. I found a lot of color bleeding on white ceilings and light gray wall near windows in 2.6 as well. It makes sense if there are bounces being calculated. It would be nice to have control over ambient lighting and GI color bleed. Sometimes, I don’t really want hyper real lighting and I loved how fast 2.5 was where I didn’t have to spend hours creating multiple lighting setups to get things to look the way I want them to.
Thanks for the further message. Feel free to still share some screenshots in any case, and I’ll also upvote the existing request on our agenda to allow you to define the GI intensity. Since the indirect lighting has been improved as mentioned by Clemens, you’ll also, in some scenes, have a slightly different output (should be more true-to-life) in regards to that compared to 2.5. Again, if you like and if it’s possible, then a few before / after screenshots would be great to let you know exactly. :slight_smile:
