Hair Material
Hello !
I’ve got some troubles with a simple scene and some differents HairMaterials assigned.
I’ve attached the scene, but you can reproduce it easily.
4 teapots with H&F, 4 differents Hair shaders assign.
First render is ok, but when i try change something, like swap 2 shaders, or copy a H&F style on another teapot, thinks begins to bug… (typically, red shader is not assign to good object)
Any idea to what’s happening ?
-Pingus-
Edit : Arg, can’t upload .max files…
You can zip the .max file and attach it, or you can email it to vray@chaosgroup.com
I’ve emailed you because looks like i can’t upload something
