Half underwater
Simple question :
What’s the best approach for creating a scene half underwater ?
I need caustics, fog and of course, I will have to put an object which will be under and above water…
Thanks in advance.
Hi Rikou,
You need additional faces for the underwater-to-above-water transition to work. To achieve this, you can create extra geometry (for example, a box) and use it as the Cutter Geom in the liquid simulator. For more details, please check the Whale Jump tutorial - Create a Box for Cutter Geom: Phoenix for 3ds Max
As for the caustic effect, you can check out the Pool example scene and learn from its settings. Phoenix for 3ds Max
Hello hammer_chen,
Thank you for your advice
I don’t have access to Phoenix and the project is done now, so after a lot of tinkering I had to find my own solutions.
Anyway, thanks for the interesting information!​
