Hi,I am trying to get this look… or something similar to hand drawing. !(
Can anyone help?
The attached image is from algorithmicarts.com)
Can anyone help?
Open the visor, there’s a perfect example of a hlaftone shader.
tahnks for replay snivlem
I’ve check them all before starting this thread but most can’t be rendered with vray.I suppose …that’s probably because this shaders use materials as texture ,which, from what I read is a technical limitation in vray…I don’t know.If anyone has any suggestions, I would really appreciate it!
Where in the Visor is the sample?
there is a whole bunch of toon examples under “toon” section in the visor, however none of them (none that I tried anyway) work with vray…You have to click on Toon example, and click on the path (otherwise some times it does not refresh)
Oh, sorry then. I haven’t tested obviously, but this is good to know.
..the shortest way would be Rendering/Toon/Get toon example…anyway ,what I am looking for is a shader who imitate hand drawing animation where outline flicker(shake) pretty often.Best example I seen on the internet is at http://algorithmicarts.com/gallery/npr-animation/. I like especially “watercolor ant” example ,but “Torus Sketch” or “Sketchy eggs” example is approximately what I am searching for .
those setups are really tricky, they don’t even work with mental ray…so I don’t really see much use in them anyway ![]()
the only way to get something similar as per my experience is to use piranesi as post prod final toutch.
i guess you dont really need to use vray to render that stuff anyway, why not just comp it in with the rest of your v-ray renders?
