Hang after render
Did I read somewhere here that the hang after render bug was fixed?
I’m using Max2013 PU5 with Vray 2.30.01 and I’m getting a 30-60 second hang after rendering. Actually it’s when you click on something, anything, after rendering, usually the VFB, but not neccessarily
Disable progressive refinement used to improve it in 2012, but it seems to make no difference now.
Is there a fix for this yet?
Cheers.
Nat.
try disable nitrous…or change display modes, ie direct x to open gl, see if that changes anything.
It’s not fixed, but it is a little better. Like Dmitry suggested, switching to a different viewport driver (i.e. DirectX) will solve the issue.
thanks guys.
Nat.
