Hang on VRayHDRI Rotate
Every time I try and rotate the HDRI (through the VrayHDRI map with RT CPU) RT Hangs and max becomes un-responsive.
I have to end task max and re-start it…not idea.
I will try a smaller test scene.
Any known issues with this??
Cheers
And include the multiplier values - same result = HANG???
could it be nitrous (on max 2012)?
Which V-Ray version is this? Can you get me more specific reproduction steps?
it just happened here, as well
… so far, no idea
I’m on max 2013 nitrous win 7 vrayRT 2.30.02
edit 1: works fine with a simple scene
edit 2: it says Error during V-Ray RT “NotifyRefChanged”
Can you get us a scene that fails to vray@chaosgroup.com ?
maybe yes,
…just give me some time to get over a deadline tomorrow …then I’ll clean up the scene file; I’m pretty sure I’ve almost isolate the issue
Here I’m,
AFAIK for me the issue was related to a forgotten instance of the hdri map into reflection override slot; the strange thing is that it was disabled!!
See image for further infos
I’ll send you in a minute a simplified scene with hdri map to investigate
Thank you for the scene file, this issue is reproduced and reported to the developers team.
Yes confirmed, this was also the issued in my scene, I had a couple of maps in the environment overrides (which were turned off).
Works great now, thanks.
The fix is done for the internal builds and it will be part of the next V-Ray release.
SP or major release ?
Best regards…
Hi Fabien,
Unfortunately can’t say yet, but if you need this fix urgent you can email us at support@chaosgroup.com
The next SP, which will come a bit after the 3ds Max 2014 release.
so this fix will not follow the usual beta path (stable or nightly), correct?
It is in the nightly/stable builds already…
