this has been realy realy frustrating. I have a scene which can render fine with buckets with the following settings
min subdivs 1
max subdivs 24
noise 0.02
but as soon as i try with
min subdivs 1
max subdivs 40 (or more, I want 56)
noise 0.02
as soon as i try with the above or more subdivs I get hanging buckets, one of the gpus (in dual gpu enabled mode) hangs and drops power usage to 50% and never complets the buckets.
When i try to render the scene with either of the gpus alone again it gets stuck in the middle of the render. The scene uses arround 14gb of the memory and i have used filecashes to bring it down.
in a sequence of 175 frames i have only managed to render 26 frames. the files usually gets stuck wither on the frame i start the render on, after 5 frames or after 14 frames… completly unpredicatable and i cannot finish my work.
I have tried with the 461.47 nvidia driver and with the 471.11, with houdini 18.5.499 and houdini 18.5.596
I have successfully rendered other scenes with both gpu’s enabled.
my vray benchmark scores in rtx mode 5432
plz help. many thanks in advance.
