Hello All
When I use the Corona rendering engine, in the final rendering stage, if I set the rendering size to 3000 pixels, it will render normally until I stop rendering, but when I stop, 3D Max hangs and freezes.
I tried with several scenes, it had the same result, I even tried with a simple scene and the result was the same again.
Let me also point out that the rendering size of 2500 pixels is not a problem and this problem is only for the size of 3000 pixels and above.
If you have any suggestions, please submit
The system I use
-AMD Ryzen 9 3950x
-64 Gb RAM
-NVIDIA GeForce RTX 2070 Super
Out of curiosity, are you using the NVIDIA denoiser at all, just wondering if that is running slow (or freezing) due to lack of memory or something (increased resolution usually doesn’t mean anything different other than more memory required, both for the CPU and RAM, or for the denoising process). Any LightMix involved, and how many light selects?
