Hardware recommendation - Asus TUF VS HP Victus VS Lenovo LOQ
Hi All,
I’m new to the forum and came across the Sketchup and Enscape software. I am on track to be a new interior designer and I am looking to purchase a laptop for work purposes. I have shortlisted 3 models based on my available budget however, I’m quite torn because I’m uncertain on which would be a better choice.
Some background information on usage
I intend to use Sketchup + Enscape for 3D modelling to provide clients with better visuals at the beginning phase of projects however, I don’t foresee doing that for every single client I take up as the firm I’m joining does have a dedicated 3D designer. I’ll probably be using AutoCAD and Sketchup more often and may not end up rendering the models with Enscape but I felt like maybe it’ll still be handy.
The 3 laptops I have shortlisted are as follows:
1. TUF Gaming A15 FA507NVR-LP049W
Processor: AMD Ryzen™️ 7 7435HS Mobile Processor 3.1GHz (20MB Cache, up to 4.5 GHz, 8 cores, 16 Threads)
SSD: 512GB PCIe®️ 4.0 NVMe™️ M.2 SSD
GPU: NVIDIA®️ GeForce RTX™️ 4060 8GB GDDR6
RAM: 16GB DDR5-4800 SO-DIMM (1 X 16GB)
OS: Windows 11 Home (64-bit)
Battery: 90WHrs, 4S1P, 4-cell Li-ion
2. Lenovo LOQ 15ARP9 | 83JC00A0SB
Processor: AMD Ryzen™ 7 7435HS (8C / 16T, 3.1 / 4.5GHz, 4MB L2 / 16MB L3)
SSD: 512GB SSD M.2 2242 PCIe® 4.0x4 NVMe®
GPU: NVIDIA® GeForce RTX™ 4060 8GB GDDR6, Boost Clock 2370MHz, TGP 105W
RAM: 24GB(2x 12GB SO-DIMM DDR5-4800)
Battery: 4-cell 60Whr
3. HP Victus Gaming Laptop | 15-fa1324TX
Processor: Intel® Core™ i7-13700H Processor (24M Cache, up to 5.00 GHz)
SSD: 1TB PCIe® NVMe™ TLC M.2 SSD
GPU: NVIDIA® GeForce RTX™ 4050
RAM: 16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Battery: 4-cell, 70 Wh Li-ion polymer
I’m unsure if there’s anything else that needs to be taken into consideration and greatly appreciate any inputs that will be received.
Thank you for reading my post!
Gehree
